Clears the identity management feature counters.
N/A.
High memory usage level reached count
Critical memory usage level reached count
Max memory usage level reached count
Normal memory usage level trap sent
High memory usage level trap sent
Critical memory usage level trap sent
Max memory usage level trap sent
Event notification sent
You can view these counters with the show identity-management statistics command.
The clear counters command also clears these counters. The following counters relate to active entries and are not cleared: Total number of users logged in, Total number of login instances, and Total memory used.
The following command clears the identity management feature counters:
Switch.4 # clear counters identity-management
This command was first available in ExtremeXOS 12.4.
